HowTo: PTT on Maestro but no audio?
brucew2024
brucew2024 Member ✭✭
Have a footswitch on Maestro C but microphone output only works if I press the MOX switch. How to fix this please?
  • David Decoons, wo2x
    you are using mic into radio and not Maestro? If so, plug foot switch into radio.
    73 Dave wo2x
  • brucew2024
    This does not provide a solution because then the slice has to be set to Tx on the radio leaving the Maestro, useless.
  • brucew2024
    Well I figured it out. Somehow I lost the setting for the Local PTT in the Multiflex settings. All is well again in the HAMverse.
