PG XL replacement fan
I am going to get a spare fan for my PG in case if the original fails.
Can someone suggest a quality replacement fan- silent and providing suitable air flow rate?
Tom
Hi Tom, I would check with Flex or 4O3A. Often these fans have speed sensors in them that need to be correct. It is not just a matter of air flow.
Hello OM Len,
They have given me fan's dimensions, its is 24V , two wire connector.
No suggestions about a specific model from IBM- Papst or other reputable manufacturers
Can you share the dimensions?
OM John,
Manufacturer provided following details:
Size 60x60x38 mm, air flow 40 cubic meters per minute, 24v, 2 wire connection.
Tom
What was manufacturer's name and model number?
Per Mr Radio:
Hello OM Len,
An update:
Airflow is in cuf/min.
Manufacturer suggests two options:
https://eu.mouser.com/ProductDetail/Delta-Electronics/PFB0624GHE?qs=Tx9Tc1LIQ%252BEfZTZP3ekWIQ%3D%3D
https://eu.mouser.com/ProductDetail/Sanyo-Denki/9G0624H1021?qs=%252B6g0mu59x7IbRENJ7MMOCA%3D%3D
Tom
Thank you very much for the follow-up and information. I have purchased the Delta fan from the US website. I will feel much better putting the amp in "Contest Mode" and hearing the fan whine away at high volume knowing that I have spare that I can replace it with when it fails.
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
