Flex 6600 N1MM+ SO2R Audio Switching Macros
W0AAE
W0AAE Member, Unconfirmed
Hello,
In past contests, I have experimented with different N1MM+ macros for audio switching in 2BSIQ/SO2R with the 6600. However, I have never gotten the audio switching to work as perfect as it could be. There is still some issue with audio only being in one ear once I start transmitting on the other "side" of the radio. I would like to know if there are any macros that can perfectly fix the SO2R audio switching issues between N1MM+ and the 6600. Below are the macros I currently have in N1MM+ for the 6600.
# CW Function Key File
# This file can be used in most CW contests that have a simple exchange
# The {EXCH} macro uses the contents of the Sent Exchange box in the contest setup
# The {SENTRSTCUT} defaults to 5NN. If you want to send another signal report,
#  change the Sent RST in the Entry Window before transmitting your exchange.
# F5 uses "!" macro for his callsign
# Do not use the {CALL} macro in place of the ! macro
# S&P F1 calls QRL? before placing the program in RUN mode for calling CQ
# To respond to caller, send F5 then F2, or ; (default exchange key) or
#   Insert, or Enter in ESM
#   RUN Messages
F1 Cq,TEST W0AAE{OTRSPOTHER RX}{END}{STEREOON}
F2 Exch,<<<5NN>>> {EXCH}{OTRSPOTHER RX}{END}{STEREOON}
F3 Tu,TU {MYCALL}{CLEARRIT}{OTRSPOTHER RX}{END}{STEREOON}
F4 {MYCALL},{MYCALL}
F5 His Call,!
F6 Repeat,{SENTRSTCUT} {EXCH} {EXCH}
F7 Spare, CQ CQ CQ DE W0AAE W0AAE
F8 Agn?,?
F9 Nr?,Nr?
F10 NR, {EXCH}
F11 Spare, CQ CQ CQ W0AAE W0AAE
F12 Wipe,{WIPE}
#   S&P Messages
F1 Qrl?,Qrl? de {MYCALL}
F2 Exch,5NN {EXCH}{CLEARRIT}{OTRSPOTHER RX}{END}{STEREOON}
F3 Tu,Tu
F4 {MYCALL},{MYCALL}{OTRSPOTHER RX}{END}{STEREOON}
F5 His Call,!
F7 Spare,
F8 Agn?,?
F9 Nr?,Nr?
F10 NR, {EXCH}
F11 Spare,
F12 Wipe,{WIPE}
I have tried to look for a confined sheet for this information, but I cannot find any. Maybe I am just not looking hard enough. However, I am curious if there is a sheet that anybody knows or has with information to "end all" macros for N1MM+ and the SO2R side of the 6600.
  • Hi!
    I have successfully used principle the same mc file for several years. Now when I use this I cannot get correct muting of other Radio when doing CQ on the other Radio. Hmmm… corrupt commands?
  • David Otto
    David Otto Member ✭✭
    Did you ever get a set of macros commands for N1MM functionkey.mc that work for SO2R audio switching?
