Loopback 2.4.x, and xdax and wsjtx NOOP in Sonoma and Sequoia...how to fix this ?????
HI all
i run xdax and acat and loopback ans wsjtx on allmy macs whihc include minis ( intel and M1) and macbook air (M1)…i run Mostly Sonoma Macos onthe mini and now have run Sequoia on macbook air…
I am unable to get xdax and loopback and wsjt to work properly in transmit in sequoia . Al indicator show i need to give xdax mic privileges. But there is no way to make that happen. and i have not hear back from Mario who develop xdax.
So sequoia is xdax/loopback killer.
Now in Sonoma , i update from 2.3.x to 2.4.x loopback..once again xdax/loopback and wsjtx do not work in transmit…. i revert back to loopback 2.3.x and all works well again…
so now i am convince maybe loopback 2.4.x is the culprit after all and not xdax.
rougue ameba has not been able to resolve this issue either…after many (4) beta versions i have tested for them…
so if there are any Mac user that have loopback v2.4.x and xdax and wsjtx working in Sonoma please let me know what you did to make it work in transmit.
Even more important is there are any Sequoia mac users, that run xdax/xcat/wsjt and loopback…what is the secret sauce you used to make it all work
any info would be greatly appreciated
Paul K3SF
Hi Paul,
W/r to Sonoma…
As you may recall, I “work around” the xDAX TX issue by running xDAX inside a Terminal window. Still works on my M2 mini running Sonoma 14.7.1 with Loopback 2.4.
Earlier, wasn’t sure if the workaround required Terminal to be in the Microphone list.
Now convinced Terminal must be in list for xDAX-via-Terminal to work.
To get Terminal into the mic list (if not in yours), I think one needs to do something that gets MacOS to ask if Terminal should be added.
I’d try running an app in Terminal known to MacOS to use the mic (such as fldigi or wsjtx). But, not xDAX, as MacOS doesn't know it needs access.
I believe this could be tried without upgrading back to Loopback 2.4 (if you are presently at 2.3):
1) Launch Terminal
2) Run fldigi or wsjtx via Terminal’s “New Command…” to see if MacOS will prompt you for Terminal mic access. For example: /Applications/fldigi.app/Contents/MacOS/fldigi (or wsjtx)
If successful, MacOS should display dialog asking about Terminal mic access (perhaps also listing the app running in Terminal). If it looks right, allow.
If Terminal is now in mic list and "on", try running xDAX using Terminal’s “New Command…”: /Applications/xDAX.app/Contents/MacOS/xDAX
W/r to Sequoia…
Only minor success on Sequoia 15.1. Requires Loopback 2.4. Using Intel T2 mini.
Sometimes can launch apps (except xDAX) from Dock. Other times, can only launch apps via Terminal (SmartSDR, fldigi, etc.).
Typically, things run fine for some tens of minutes. Then, SmartSDR and xDAX freeze. Usually can be restarted, but will later freeze, again.
Mike WA7IJV
hi Mike….
I tried your work around…didnt work out for me…
guess i'll wait and see what new from next version of sequoia
One good thing i found out is that macssdr works fine in sequoia even its dax function which i have been able to get loopback to work with properly…
i will continue to use my macbookair M1 as test bed
but
operational mac mini's will stay on Sonoma till i get the Macbook air working the way i like with Sequoia
and
i wont be in any kind of rush to get new M4 Mac Minis either ;-)
thanks again
Paul K3SF
Sorry you weren’t able to get Terminal into the microphone list.
Sequoia 15.1.x finding… I turned MacOS inbound firewall off - now everything launches from the dock (except xDAX). (Firewall impact was an early discovery by the Mac community with 15.0, but turning off didn’t originally help me)
Tested the last two days, no freezes. If I turn firewall on, SmartSDR freezes immediately.
But, I don’t like keeping firewall off. So, the wait for Apple fix continues…
Would running Mac SmartSDR’s own DAX TX, while using xDAX’s multiple RX be a possibility on your Sequoia Mac?
Good luck, 73…
Mike WA7IJV
HI mike
tried your suggestion…
where i ran xdax for received signals from macssdr thru loopback to wsjtx
Works with multiple simultaneous slices ( tested with 4 slices max on my 6600m)
and
so i use macssdr dax for transmit also going thru loopback and wsjtx ….
bit of rube goldberg setup but works…
also requires xcat to run to with wsjtx
just have to manual select TX slice in macssdr right now
all this works with macos 15.1.1sequoia so far
loopback 2.4.5 and wsjtx 270rc7 and XDAX 2.0
on macbook air m1
however if i want to use slices that are on the main panel of 6600m for FT8 or other digital work
none of this works ;-((
hate to loose that capability
Paul K3SF
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
