SO2R with Flex 6600 and Expert 1k5 Amplifier
Hi everybody,
I would like to do SO2R with a Flex 6600, Expert 1k5 amplifier, antenna genius and if needed 1A2R switch. Is there already a solution or is it even possible?
Best regards and 73!
Fabian, DL7FP
I own both a 2K-FA and a PGXL and have them connected to my 6400M and 6600M. If I were going to run SO2R I'd use the the PGXL to do so. It is designed for the purpose and requires no Rube Goldberg-style wiring arrangements to do so The Expert amps are designed to implement a "semi" SO2R setup in that the most recent transmitting input receives the "preferred" transmit antenna for a given band while the other input is connected to a multiband antenna for receive purposes. If this type of arrangement is adequate for your needs, I'd contact Dan, KC5PCB, to see if he can make for you an interface cable that will control both inputs of the amp from a single radio. If you have 4 or fewer transmit antennas you may not need the antenna genius since the 1.5K supports that many itself. Note: if I owned just one amp it would be the 2K-FA. It is quieter, requires less drive, and runs cooler than the PGXL. The advantages of the PGXL are just the simplicity of connections and its implementation of true SO2R
Hi Rick,
thank you very much for your reply. That's what I suspected, so I'll keep an eye out for the PGXL!
73 Fabian, DL7FP
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
