SmartSDR v3.8.19 Maestro A malfunction
Hello,
the update has worked so far and with the PC the radio runs without obvious problems.
But I can no longer work with my Maestro A.
The button "MOX" no longer works. Button has no action at all.
When I use VOX, the device stays on continuous tx after a few times activation by vox.
Going to receive only works by removing the TX flag.
Using Maetro as flexcontrol it behaves normaly.
Regards, Hardy
Hi Hardy, you might try a factory reset after exporting your profiles. If that doesn't help, I would submit a help desk ticket.
Thank you Len,
i did reload the profile at Maestro and it now works!
73, Hardy
Excellent!
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
