frequency calibration
WX6P
Hi, is there a write up on how to calibrate frequency on a 6400 without GPS using WWV?
Page 150 and on in the Flex user guide at https://www.flexradio.com/documentation/smartsdr-software-user-guide-pdf/
Radio Tab:
Calibrate the local oscillator by performing the following steps:
1. Select a signal of known frequency, with strength greater than S6. In the US, WWV is a good choice.
2. Enter the known frequency in the Calibration Frequency field
3. Click Start. The radio will tune to the signal and compare its tuned frequency to the declared frequency. The difference will appear in the Offset field. You can also enter a value directly into the Offset field.
I won't repeat it all - you can follow it in the manual.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
