Maestro C won't connect to my iPhone
My Maestro see's my iPhones hotspot, and I am entering the password correctly, the phone ins right next to the Maestro and is the strongest signal it sees, BUT it will NOT connect…any adivse?
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    Does your iPhone use any punctuation in the SSID (the network name)? Frequently Apple will auto-name your hotspot SSID like "John's iPhone" and the Maestro cannot work with the apostrophe. If this may be your case, re-name the WiFi SSID to something with ultra-plain letters only and re-try.
    HTH
  • John Watson W4JCW
    John Watson W4JCW Member ✭✭
    edited September 2024
    Initially it did have the apostrophe, I renamed it without…still will not connect…
  • On iPhone hotspot screen select "maximize compatibility". Forces everything to use 2.4ghz mode.
  • Charlie_KB8CR
    Charlie_KB8CR Member ✭✭
    I have found that to connect to the hotspot on my iPhone (It's an older iPhone X), you must have the Hotspot screen open on the iPhone when you connect, THEN you can close the screen on the phone. I have had to do this to connect my DMR hotspot to the phone.
    Charlie KB8CR
