SmartSDR Slice A is not centered on Screen
On SmartSDR, Slice B is centered in the middle of my screen. But for some reason Slice A is not. Why exactly do I need to click or drag or whatever to get it centered?
Mark Griffin, KB3Z
Hi Mark… when you start SmartSDR, which slice comes up? Is it A? Where is it located? How do you relocate the window to where you want it? When you close down SmartSDR, how do you do it? Via the close window button in the top right? Are you directly connected from computer to radio or operating remote?
What happens on my installation is that either SmartSDR or Windows (I'm not sure which) "remembers" the position of the window on the screen from when I closed it last. So in my case, I have positioned my Slice A to use only the top half of my screen, dragging the window to the left side, then using the resizing gadget in the lower right corner to get the screen to take up the desired room on the screen. Each time I restart SmartSDR, Slice A comes up and is located in the same position on the screen. Is this not what's happening for you?
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
