QTY 2 Antenna Genius 8x2 Switches Connected to One 6600
I'm in the process of changing over all of my antenna switching to a pair of 4O3A Antenna Genius's (AG). I'll have an AG mounted at the base of each of my two towers.
The two AG's will be connected to a Stack Match which will be connected to my 6600. The idea is having the ability to pick Tower 1, Tower 2 and both Tower 1 and Tower 2 combined. This will allow me to spray my signal to say EU and the Caribbean at the same time during a DX contest. Or one antenna east and the other west for domestic contest like SS.
When I bring up the Windows AG App., I can only connect to one AG or the other but not both at the same time. I'm running version 4.1.8.
I need the ability to have both AG's select the same band. How can this be done if I can only connect to one AG at a time?
Rich - N5ZC
Would running two instances of the software allow you to do it, possibly?
Phil
Hi Rich, if Phil's answer doesn't solve it, reach out to 4O3A to see if they have a solution.
Rich
You need to run 2 instances of the utility, it can be done and I've got it working with 2 AG's myself. You only need to install it in 1 location but just open it up twice.
When you configure each AG, name them so you know which is which e.g. Tower 1 and Tower 2.Open the utility and connect to the first one, then open the utility again and connect to the other.
Rich M5RIC
Thanks Phil and Rich. I'll set it up for 2 instances.
Rich, I saw your question on the 4O3A community. I replied with a question but the guys at 4O3A have not replied as of yet. Maybe they will make an update to the utility one of these days so we can use one instance.
Rich - N5ZC
Well that was easy.
Rich - N5ZC
If you close the apps down when you open the first and then second instance, both will connect to the same AG, close one and then you get the choice which one to choose again.
Rich
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 403 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 371 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 194 FLEX-8000 Signature Series
- 916 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 744 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 961 Third-Party Software
