The Tune button and the API ....
Sorry if I have missed the obvious, however is there a means to determine if the 6400 is in Tune rather than TX mode?
Many thanks
Andrew G1RVD
Hi Andrew, Yes!
Look in the G09_TransmitEvents.ino file in Enzo's library:
In my case, I am just using the fact that the Tune button in SmartSDR was pressed to take my TeensyMaestro out of screen saver mode.
Ah ... Thank you Len.
Also ... thank you for your efforts to keep the Library alive.
I've ported it to an Arduino GIGA with only one change necessary. The GIGA and an external W5500 Ethernet board, didn't like having interrupts suspended in the int FlexRig::send(String cmd, int parserId) function in FlexRigTeensy.cpp around line 108.
Otherwise, although I'm still learning my way around, evidenced by my question, it seems to work well.
Andrew0 -
I'm glad it is working for you Andrew! What are you building with your GIGA?
Hi Len,
I'm building a SSPA using the Ampleon ART2K using W6QPL/DJ0ABR's designs as inspiration. Plus a Vacuum Cap & roller inductor auto ATU, driving an antenna switcher. The LPF is driven from the Flex API (seems to be working).
Could I ask you another question: What's the best way to determine that the Flex has entered RX mode, i.e. stopped TX or Tuning?
73 Andrew
Hi Andrew, It's not intuitive, but look in G08_InterlockEvents.ini for the state_event:
That is the only one I use, so I commented out the rest to save space.
In the onInterlock_state() routine, I test for the word "TRANSMITTING" to determine if it is transmitting for any reason, including the tune button. There are several other states, but I can't remember what they all are now. A Serial.print(fRig.interlock.state) statement will show you the states that the radio goes through as it transitions from RX to TX and back. For most purposes, just testing fRig.interlock.state for equal or not equal to "TRANSMITTING" should suffice.
In this example, I am only using the transmitting state to turn on and off a little red circle to annunciate transmit status on the screen.
Wow, that is an ambitious project! You won't likely run out of IO pins with that Giga board!
Hi Len,
The interesting feature of the GIGA is dual cores. I have the smaller (M4) core sensing real time signals like the power meters and stepper motor POTs (& controlling the steppers), and the larger M7 core handing the slower communications tasks (mqtt to node-red and CAN to the power supply, etc).
It's not working yet … let's see 😀
Thank you for your tips. They save an awful lot of time.
73 Andrew
The Flex seems to send READY when coming out of TX.
Ah, that's right. I can't remember why that did not work well for me. I found that the TRANSMITTING message was the one for my needs.
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 932 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
