Rotator Genius, and Yaesu G-450A Rotator
KR5OG Paul K
I have just received my Rotator Genius, and am in planning stage for installation and setup. The G-450A uses 35vac and having a hard time finding a 35vac supply source, short of using the Yaesu controller as a power supply only.
has any one using the RG with the G-450A rotor? What are you using for power?
The later G-450 rotors use DC power.
Paul Kr5og
Troy Tx.
Well, Color me Nuts. 😉 After rereading the RG manual, I find that I can use a DC supply and the RG will convert the DC to AC. This is done with Dip switch 6 on the Set A block of switches.
Paul KR5OG
Which wires did you connect between the Yaesu rotator motor and the RG? Do you mind sharing your final configuration of the dipswitches? Thanks!
Hi, could you share how was the pinout you connected to the genius?0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
