FLEX 6600M wired via USB to SPE 2K, but SPE is not following Flexradio bands change
I could set the HI/MID/LOW power limitation as per SPE 2k manual and I see on my Flex the power is well set and changing for each band/power level, this whenever I change band or Power level on SPE 2k. I can't set 100% manually on SmartSDR due to config it limits to the max set power on the SPE (which is correct), by using the arrow on the SPE 2K I can fine tune the limit.
BUT whenever I change band on my Flex 6600M, the SPE does not follow (only once I start transmitting as it has an integrated circuit to detect the band). I think it should follow automatically, without waiting for me to transmit....
I set SPE CAT interface to FLEX 9600Baud as on the USB CAT cable parameters
Data bits = 8
Parity = None
Stope bits = 1
Flow control = None
What am I doing wrong?
Thank you.
Your schema is right and the FDTI is standard. Looks like you have one channel (RX or TX) on (hopefully) the FTDI that is not working.
"Note that if I am using below wiring scheme… the band change does NOT WORK, SPE does not follow my band change, BUT I can set the Power Level and they keep in 'memory' for each band/power level." SPE is transmitting, Radio is receiving fine; Radio transmits but nothing is received.
"If I invert orange and yellow wire, the SPE follow the FLEX band changes, BUT the Power Level can't be adjusted." Doesn't make sense, if you connect RX and RX, TX and TX nothing should work.
- Double check the soldering on the SPE DB15, make sure there is not a sort of shortcut on the TX or RX pins.
- In the USB Cable Advanced configuration, under flow control, check different options.
Here is how I have mine set up for my KPA 500 amp:
Do you have the cable type set to CAT? On the radio side of your interface cable, do you have RTS tied to CTS? I am not sure if this is necessary for the Flex radios.
From The SPE 2K manual:
You might want to verify that your RX232 and TX232 lines are not swapped. It is very easy to do because one side's TX is the other side's RX.
Looks like the SPE can communicate with the radio (Setting power) but the radio doesn't communicate with the SPE (band change not following). Double check the wiring. Configuration should be OK. 73, Max
More from the SPE manual:
Make sure that FLEX-RADIO is selected as the CAT interface. If you already have this, you might want to try a baud rate of 115200. The manual references the CAT CONNECTIONS chapter, but I did not find it. Somewhere else it references 115200 as a baud rate, so maybe that is the default for this amp. Not really sure that is it, but lacking a way to test it, maybe you can give it a try.
Thanks! TX and RX were inverted... now SPE is following Flexradio band change.... but the Power setting is not working anymore....
Should I jump CTS and RTS on Flexradio side? Which PIN are those?0 -
ell thank you for your help, but it does not work for me….
I have a USB FTDI cable without DB9 connector, but loose wires. Based on below standard color code CTS and RGS are the brown and green. I shorten them but then power does not adjust anymore.Note that if I am using below wiring scheme… the band change does NOT WORK, SPE does not follow my band change, BUT I can set the Power Level and they keep in 'memory' for each band/power level.
Maybe my USB FTDI cable is not standard???
Above is my Flex Setting matching the SPE set to CAT FLEX at 9600bauds
Thanks i changed the FTDI USB cabke to another spare and it worked straight ahead. I guess the other FTDI chip/cable has a defect
73s
- 339 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 367 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
