Radio Controls processor settings not saved
Greg6498
Greg6498 Member
edited July 2024 in SmartSDR for Windows
I just received my Flex 6400 a few days ago, using SmartSDR for Mac, and have noticed that if I adjust my microphone processor settings in the Radio Control panel, the information is not saved. If I change bands the processor setting goes back to zero. I also tried saving under Radio-Profiles-Microphone but the information is still not saved. I contacted the SmartSDR author and he said the info is saved locally by the radio and to reset the Client ID. I did this, but the settings still won't save. Can any of you help me with this?
  • Art Wilcox
    Art Wilcox Member ✭✭
    There is a check box in the setup configuration
    "Save settings on power down" you need to check this box in setup settings. Then set the profile for tx and Rx and power down. Power back up and the settings should be there.
    Art KB1YAP
