How to view signal in dBm
VE7FM
When running SmartSDR on my PC I always have signal strength in dBm enabled - is there anyway to enable this with the 6600M Maestro interface?
Running 3.7.4.
Running 3.7.4.
Hi… I don't have a Maestro, so those with one please chime in. On the SmartSDR interface, if you click on the dBm at the end of the meter, it will switch to S units. I suspect the same thing may happen if you tap on the same place on the Maestro interface — it will switch between dBm and S units.
Yes, it is easy to do with SmartSDR on a PC, but the same clicking doesn't enable it on a Maestro.0
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
