How to view signal in dBm
When running SmartSDR on my PC I always have signal strength in dBm enabled - is there anyway to enable this with the 6600M Maestro interface?
Running 3.7.4.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi… I don't have a Maestro, so those with one please chime in. On the SmartSDR interface, if you click on the dBm at the end of the meter, it will switch to S units. I suspect the same thing may happen if you tap on the same place on the Maestro interface — it will switch between dBm and S units.
  • VE7FM
    VE7FM Member ✭✭
    Yes, it is easy to do with SmartSDR on a PC, but the same clicking doesn't enable it on a Maestro.
