Maestro C and INRAD M-629/DMS-1 Base
I recently bought the following from FlexRadio to use with my Maestro C:
INRAD M-629 with DMS-1 Base
INRAD DM-F Adapter Cable
Microphone keying from the INRAD base works fine with the Maestro C, but not the microphone audio. I have tried every combination of adapters and settings I can think of, and I simply cannot get any audio to pass! The instructions read that this should be as simple as connecting the TRS connector on the DM-F adapter cable to the microphone side of the Maestro Y cable… but no dice.
The FHM-3 hand mic works great, but I prefer the desktop microphone. That, and, after paying over $200 for the microphone, base, and adapter cable, it would be nice to have something more than a paperweight 🤣
Has anyone able to make this combination work or suggest what might be going wrong?
that occasionally happens th me and last time it was because I somehow switched the switch on top of the mic off, I never use it but…
The only other thing I’ve done is to be in the digu mode instead if USB.
Tom
N9RU
I think that the problem is that the Maestro C takes a TRRS (CTIA standard) plug, not a TRS plug. I think that you also need another Y cable to break out the mic and headphones, but I am not sure. I would contact the Flex Help Desk, they will know what you need.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
