VFO A and VFO B do not accept different bands at the same time
For example 80m on VFO A and 40m on VFO B cannot be set, not even by entering the frequencies using the keypad. Works only with QRGs within the same band. I have no such problems with SmartSDR Mac/iOS. Can anyone confirm this or give a hint on how to solve the problem? I would like to use different resonant antennas this way.
I do not have that problem.
Are you sure you are entering the frequency correctly and its not just failing to set through wrong entry?
Since what is supposed to work must work, after your observations, I started troubleshooting by simply resetting the radio (6400) - and lo and behold: now it works, with two pan adapters, as recommended! It's a bit surprising that this helped, since it already worked before with SmartSDR. Perhaps the touchpad was acting up with the numeric keypad, because after entering the first digit of a new frequency in VFO B, the display always jumped to the previous value in the same band as A and vice versa. However, now the problem is solved, ufb! mni tnx for the encouragement here, hi…
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
