MRP40 (CW Decoder) with the FLEX 6400
Thanks for help !
73, Rainer
MRP40 does not work well with Flex 6400. Below you can see a comparison between it and the decoder in SDC.
MRP40 was not written to interface with SDR. It is also costly at nearly 60 Euros whereas SDC is only a $10 dollar donation and that gives you a full Flex API interface with much more than a decoder: CW Skimmer, RTTY Skimmer, Panorama and AGC-T automatic control, Contest module and so on.
By all means try MRP40 for yourself of course. Simply download, install and open Options>View>Soundcard and select your DAX audio stream.
Thanks a lot Erik !
I was told by many hams that MRP40 is the best for CW but was very disappointed when I asked Norbert about installation with Flex and got the answer " Der Flex 6400 wird sicherlich einen Audio Ausgang haben den man an an einen Computer mit MRP40 anschließen kann. Zum Senden gibt es entsprechende Hardware / Sw Interfaces Siehe MRP40 Webseite und User Manual. "
I found that it's better to ask here and are happy you gave me the advice to use SDC. I will try that for sure !
vy 73, Rainer0 -
Hi Erik,
is SDC only working after registration ? I've installed it but the setup is not working
as in the video.
73, Rainer EA8DMF0 -
hi Rainer,
Registration of the program is not a prerequisite for its use.
After registration, you will have the following opportunities:
- You can use SKM Server together with Flex radios.
- You will get the opportunity to connect through the SmartSDR-API protocols
- Access to the Contest module will be open.
Support the project on the SDC website with any amount available to you (normally $10). In the payment note, be sure to include your callsign and e-mail address to which you will receive the registration key!73 de Erik
Thanks Erik !
Yuri already answered and I learned that he is living near some very good friends of mine. I have been in Kharkiv in 2002 and met some very nice people there.
tnx & vy 73, Rainer0 -
Ok Rainer, very good. Yes many nice people there and all suffering badly. A terrible shame. But Yuri keeps going for us Flex people. A great man.
Erik.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
