Advice on moving to SmartSDR for Mac please
I am currently using SmartSDR for Windows together with connected apps:
Log4OM logging software
Slice-master that runs
- WSJT-X, used for FT8
- CW Skimmer
I have experimented with Fldigi but do not currently use it.
My predominant operating mode is SSB but I would like to make better use of CW and FT8
I have a Flex 6400 with Power Genius XL and Tuner Genius XL. All are located remotely from my operating position and connected via a 1Gbps LAN
The PC I use at the operating position to run all the software is an Intel NUC with Windows 11. It has now reached its performance limit and is frequently at 100% CPU. freezes from time to time and probably needs to be replaced.
I already use SmartSDR on the iPad and like the features it provides and so am actively considering replacing the NUC with a Mac Mini that should have better performance. I also see the reviews here for the HaliKey that would let me connect my iambic paddles directly to the Mac which is a real winner for me.
I would prefer to continue using Log4OM but there is no Mac version - could I run it under parallels? Would I use xcat to link to it and does this work?
Similarly would WSJT-X work under Parallels?
Has anyone else made this sort of transition with similar modes/applications? Any advice gratefully received.
Thanks and 73
Andy G8TJQ
I'll be interested to hear / see / learn how this works for you. I use similar software on Win10 / Win11 including Bootcamp on Mac, but that has a finite future. Log4OM is the problematic software: windows only.
Andy,
I have been a SmartSDR for Mac (and iOS on both iPad and iPhone) user for several years now, and also have a Windows 11 Smart SDR for Windows station setup. Mostly remote operation of SSB, FT8, RTTY, CW and SSTV. I use a Mac Mini M1, and operate both an older Flex 6300 and a Flex 6400 at two different locations.
I much prefer SmartSDR for Mac to Smart SDR for Windows for several reasons:
- Smart SDR for Mac is far more integrated. FT8 on the Mac just works. No fuss, no bother. Logging is built in to it also, although I am not a contester and I am certain there are more advanced features in other logging programs. And if you need to use a more sophisticated logging program, SmartSDR for Mac has built in ADIF export/import and QSL management. Every time I use Smart SDR for Windows and want to access a mode such as FT8, I spend an inordinate amount of time fiddling with the various interface apps. Same with the logging apps. Everything can be made to work with SmartSDR for Windows, but its just more of a hassle to set it up. Some folks like working through all of the Windows interface issues and have a deserved sense of pride in their ultimate success. I just like to operate ham radio!
- Support for the Flex radios is really outstanding. I have found the support team at Flex available and knowledgable for the hardware as well as SmartSDR for Windows. SmartSDR for Mac has Marcus Roskosch. Marcus answers all of his inquiries personally, and is the developer of the software. Don't know how he does it, but he does. And he sticks with a problem till it is solved. And he has a helpful web site of his own.
- As to integration once again, SmartSDR for Mac has RTTY and CW built in.
- iOS versions of SmartSDR for Mac are available, and work remarkably well. If you want to impress a non-ham, whip out you iPhone and work DX from anywhere. And on a Mac Tablet, it has all of the features built in.
- Windows and Mac both have their devotees for their respective hardware and software. I am almost a full time Mac user now, and haven't looked back. I keep a Windows 11 Dell machine up to date for the occasional time when I have some unique software needs. If you have not used a Mac, you will have some adjustment period, but there are excellent support site on the web for Ham Radio on a Mac. As a general rule, you will find that Mac world does it better, and is far more integrated between PC-Tablet-iPhone. Mac world is more of an integrated system of software and hardware whereas Windows is mostly just a PC world.
- The MacMini is the sweet spot of Mac PCs, although many people like the notebooks. But I like my 32" screen on my MacMini more than my MacBook Pro 16" screen.
I hope this has been helpful, and that others might chime in with their views.
Good Luck and 73s…
Bill
KK4C
3 -
I'm a bit late to this…
WSJT-X does work in Parallels just fine.
You will want to purchase a product called Loopback. Loopback makes it possible to route audio to any application, including into Windows in Parallels if you so choose.
But as Bill said, there really is not much need for WSJT-X. The SmartSDR Mac has FT8/FT4 built in. CW and PSK, RTTY as well. All integrated. No external software needed.
You can configure the logbook in SmartSDR Mac to send UDP broadcasts so you can probably get Log4OM to pick those up however I am not a Log4OM user so I can't say for sure. But the built in logbook works well and updates LOTW, eQSL, ClubLog and a few others.
The one sticker is CW Skimmer. I have not spent much time trying to get this to work, but routing the DAX IQ channels over to it running in Parallels may be tricky. I spent a fair amount of time talking to the CW skimmer author about a Mac release and he never came through. I offered to even write it for him but nothing happened.
It is one of those things that I would love to have but don't really need. Using spots and RBN you can get most of the same info that CW skimmer kind of gives you and both of these spotting tools are built into SmartSDR Mac.
Hope you will post here what you decided.
One thing I have found with SmartSDR is that FT8 decodes tends not to decode all of the FT8 signals. Maybe 90% of them compared to WSJTX? Not a huge deal but thought I would mention it.0
Thanks Gord, @Bill, Mark and @Mango
Following @Bill's original advice I decided to try and wean myself off the Windows version and as far as possible use SmartSDR for Mac. I bought a Mac Mini and was quickly impressed by the level of integration of a variety of modes and features in the Mac product. I suspended my use of Log4OM and moved exclusively to the built-in logbook feature and this has been particularly useful for FT8 (see below) with the autocompletion of QSOs.
I routinely use the logbook feature to update QRZ and LOTW. I have not done any contesting so can't vouch for it's level of automation or feature set.
At the time I wrote my original post I was pretty much using SSB for more than 90% of my QSOs with occasional use of FT8. In the time that has passed I find myself using FT8/4 more regularly and the ease of use of the buil-in FT8/4 facility has made this mode of operation intuitive and easy.
I have been in touch with Marcus when I found some wrinkes in the iPad version of SmartSDR and found his response and support to be excellent - I now use his SDR-Control app for Icom too.
One thing I haven't used is the CW feature - I think that's a job for later in 2025.
So thanks for all the observations and advice - for me, moving to the Mac Mini and the mac version of SmartSDR has been smooth and I much prefer it to the Windows version.
Best 73
Andy
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 985 Third-Party Software
