Saving a Global Profile
Hello so if I set my Flex 6400 Smart SDR version 3.6.8 up for a 20 meter net I do everyday and set my EQ and ic settings then go to Global profile and give it a unique name. Then the next day launch that profile. I my settings will be set as it was the day before ? If this is the case I love this feature.
  • Glenn Depp
    Glenn Depp Member ✭✭
    That is exactly how it should would.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    and for me, that's EXACTLY how it does work!!! :-) I have set up global profiles for each of the bands/segments (10m CW, 10m PHONE, 15m CW, 15m PHONE, etc.) and use them exclusively.
    HOWEVER, every once in a while you should go back and re-adjust the AGC-T for each band.
