Output Control
Is there a way to set a limit on the amplifier? Meaning I only want a MAX of 600 watts output. Is there a way to set that? Other than turning down the power output on the 6600? Or do you get what you get?
Hi Glenn, what amplifier?
The Flex Amp. PGXL
The output power is strictly determined by the input power, so you limit the output based on how you set the RF Power on your 6600. There is no power output control on the amp itself.
Use the TX Band Settings in SSDR to set the power output level you want, for each separate band.
I assumed that was the only option. Thx
Glenn, there is a PGXL / Flex radio Node-RED FLOW that Alan helped me with that I use so that when I hit TGXL Tune on the Flow it disables the PGXL and raises the Radio power to what ever I want the power set at when tunning the Antenna, then when I go to operate on the PGXL it sets the radio for the Power I want out to drive the AMP. It really automates tuning the TGXL / Antennas tuning. When running barefoot it sets the power to a settable setting
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
