N1MM 7 LOGGER32 WITH MAESTRO AND 6400
Richard Zalewski
If I send from a key I hear in monitor. If I send from a memory it keys but can not hear in monitor. This is the same for both contest and logging programs.
Hi Richard, yes that is how it works, at least for now. Flex is aware that most people want to monitor the CW from apps like N1MM. I don't know if they plan to change that or not.
I forgot to mention that N3FJP's ACLog logging program uses the WinKeyer protocol in concert with SmartSDR CAT to send CW. The way that they did it, you can monitor the CW being sent. For my setup, I just needed to set up a WinKeyer port in CAT to make it work.
Tnx Len, at this point at least I know it is not me. Can not believe this would not be a high priority. No monitor while sending from N1MM CW…
- 652 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
