Maestro Firmware
Roger Miller
Roger Miller Member ✭✭
Looking at a Maestro A. Does the firmware on the maestro have to match the 6400 firmware?
    Hi Roger, yes, the client (Maestro, SmartSDR) must match the server (radio).
    If the Maestro is at a lower version than the radio, there is no cost to upgrade the Maestro.
    If the Maestro is at a higher level (i.e. V3.xx vs 2.xx), you either need to downgrade the Maestro or upgrade the radio (possibly at cost, depending on the max license).
  • Roger Miller
    Thanks.. That clears it up.
    Riger
