Handling cluster clicks when two computers on network connected to LAN and Flex?
I have added a second computer to the shack . When both computers are in operation I often have 3 slices/pandapters open. All works as desired except when I click on a DX cluster spot on computer A, the slice on computer B goes to that frequency. Not computer A. If I click on a spot that is on computer B, the open slice on computer B QSYs., just as desired. Any ideas how I can get Computer A to work where clicked-on spots perform the task on computer A?
FYI : Computer A runs SmartSDR for Mac OS with MacLoggerDX and Computer B runs SmartSDR for Windows with Dxlab's Spotcollector.
Computers connected to 6600 via LAN.
Andy K3UK
Andy
I assume you are using MLDX for cluster spots.
In MLDX's radio configuration, there is a pull-down menu for selecting the desired client. Since you have two clients, be sure you have the desired client selected for MLDX to control.
Below shows the same. I have two clients.
Alan. WA9WUD
Aha ! I poked aroundd in that area but decided not to change anything. I will do so today. Thanks
Andy K3UK
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
