Smart Link W/Inseego M-3100
I have tried everything I know to do and can not make the Verizon hotspot work with Smart Link. The spot has one lan link spot and can be port forwarded. It just does not work!
Is anyone out there using the M-3100 for Smart Link?
  • i use an Inseego at the users end and it works fine. If its at the radio end I suspect its behind your carriers firewall CGNAT which will prevent Smartlink from doing its stuff
  • wa5bl
    wa5bl Member ✭✭
    yes, user end good. Just has a flaw somewhere that they will not admit.
