Fan Noise
David, K1MT
HI David,
Reports on this are all over the map. The question is complicated quite a bit by the fact that Flex has had multiple PGXL firmware updates specifically focused on improving fan noise. So a particular commenter might be reacting to an older algorithm which been improved since. All of this along with the fact that there are three user selectable fan modes, each of which behave differently. And of course how hot the finals get depends on the power and mode you're using. Reports one way or the other often omit these and other critical details so it's hard to interpret them.
For me the fan noise situation has improved dramatically since I got my first one in 2019. It's much quieter than the Yaesu Quadra I had before but not as quiet of course as the tube amps I've had like the ACOM 2000a. Of course solid state amps always have significant fan noise. It's the nature of the beast. And for what it's worth, the ACOM 2000a made a terrible racket changing frequencies and bands where the PGXL only makes a few relay clicks doing so. By the way, when used with Flex stuff (radio, tuner, switch) it's connected and controlled by one Ethernet cable so you can place it some place where you can't hear it at all.
One last thing, the PGXL has three different fan groups (LDMOS FETs, harmonic dump and power supply) each with their own fans and control loops. They come on at different times depending on what's going on. Each sounds different and my take from reading comments is that people are more or less sensitive to particular fan sounds or pitches.
Bottom line is, assess comments on this carefully. You really should try to use one yourself before deciding what you think. I think Flex has a 30 day return policy so you could try it out and send it back if you don't like it but of course verify that before ordering !
Good Luck ! Russ KR6W
I have a SPE 2K-FA and a PGXL. I often operate both at the same time and while the changes to the firmware have made the PGXL quieter than it was originally, it is still noticeably louder than the 2K-FA.
So take the PGXL put it in a rack away from the operating position and noise solved. Mine is right next to me and the fan noise does not bother me at all.
The important point is how you operate and which mode.
I operate FT8 that is a very high duty cycle. Much heat to dissipate.
if you operate SSB or CW less heat to dissipate.
Are you a contester where fatigue is a factor.Do you use noise cancelling headset?
I located PGXL in another area. I can’t hear it at all.
Find a ham that has one and listen to it. Go to Dayton and see it there.
My old tube amp fan made a racket and could not remote it in another room.
Bill
W9JJB
- 362 Community Topics
- 623 The Flea Market
- 8.1K Software
- 54 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 9.2K Radios and Accessories
- 28 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 764 Peripherals & Station Integration
- 986 Third-Party Software
