Is there a memory bug in 6600 firmware?
Hello @ve7ovy ,
I have a 6700 and use the radio for both MARS and SHARES.
It is a "feature" that is a bit annoying… when a frequency is chosen the software applies the mode (USB/LSB) that seems most relevant for Amatuer operation on the band. Typically, LSB for 160-40 meters and USB otherwise. But MARS frequencies close to those bands are also impacted by this design issue.
I do use GLOBAL profiles to select my most often used frequencies… and these seem to come up correctly almost every time.
I use ION2G for ALE and, sometimes again, the mode is "conveniently" shifted on the radio for the frequency selected… but, after I make a manual change it usually sticks (until it doesn't).
I also use FRStack… and that program will always set things correctly when choosing a frequency.
I hope this insight helps.
Hi John. Thank you for your comments and observations. Sounds like I’m not the only one that experiences these occasional anomalies in the memory recall.
Interesting point that it may be related to a rule in firmware that 40 m and below must be LSB. Most of my issues have been with frequencies below 40 m, But not always / that’s the puzzling part! I have a specific frequency just under 7 MHz, which consistently comes up as LSB when I do a recall memory. Maybe it’s close to the band edge and those band edges are perhaps not hard and fast at exactly 7 Hz for example.
Perhaps I’ll put in a helpdesk explaining my observations and commenting that I’m not the only one and see what happens. it is quite annoying when you are on a net that changes frequencies and this happens randomly.
Kevin1
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
