Integrating a TGXL tuner with a Yaesu FTDX5000
DaveG3UEG
Member ✭
I would like to integrate a TGXL tuner into my station. The rig is a Yaesu FTDX5000 which is controlled with a Yaesu SCU-17 interface unit (for digital mode control) which uses the CAT connector on the FTDX5000. Is there a way to also link to the TGXL tuner in this situation?
I can't use the BCD band data connector, or rely of RF sensing as these only allow one tuning solution per band and because of narrow bandwidth antennas I need to have several tuning solutions per band.
Flex technical support think a simple Y cable will not work.
Has anyone found a solution to this situation? Any help or suggestions appreciated.
you will need to split the CATbout of the Yaesu. I have done it several ways, including using VSPE.
I’d start with checking with one of the Yaesu groups.73
- 691 The Flea Market
- 197 SmartSDR+
- 461 SmartSDR for Mac
- 113 Aurora
- 349 FLEX-8000 Signature Series
- 976 Genius Products
- 483 Power Genius XL Amplifier
- 323 Shack Infrastructure
- 228 Networking
- 484 Remote Operation (SmartLink)
- 146 Contesting
