WinKeyer
Ed K5YZW
I've been told I need two WinKeyers to key my Flex 6700 remotely. Can someone tell me how to configure the two WinKeyers? If I have a Maestro, do I also need a WinKeyer, or can I have just one WinKeyer on the Flex 6700 side? Thanks, Ed K5YZW
Hi Ed, If you have a Maestro, you can use it remotely with a key or set of paddles without any external keyers.
It depends on your scenario and how you want to approach it.
Maestro is the simpler but more expensive solution.
With just one winkeyer you can try the WKFlex solution:
That sounds great, Max. I just got a WinKeyer USB so I look forward to trying out your software. I will let you know how it goes. Thanks, Ed K5YZW
- 394 Community Topics
- 670 The Flea Market
- 176 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 80 Aurora
- 321 FLEX-8000 Signature Series
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
