WinKeyer
Ed K5YZW
I've been told I need two WinKeyers to key my Flex 6700 remotely. Can someone tell me how to configure the two WinKeyers? If I have a Maestro, do I also need a WinKeyer, or can I have just one WinKeyer on the Flex 6700 side? Thanks, Ed K5YZW
Hi Ed, If you have a Maestro, you can use it remotely with a key or set of paddles without any external keyers.
It depends on your scenario and how you want to approach it.
Maestro is the simpler but more expensive solution.
With just one winkeyer you can try the WKFlex solution:
That sounds great, Max. I just got a WinKeyer USB so I look forward to trying out your software. I will let you know how it goes. Thanks, Ed K5YZW
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
