Error "Object reference not set to an instance of an object" since version 1.2.11
V31DL
I receive the error "Object reference not set to an instance of an object" since using version 1.2.11 when I try to open device settings. Try to open it a second time is without the error message but when trying to save I get the error messsage "Error updatin Tuner Genius device configuration!"
you may need to do a factory reset of TG, or from the app, select firmware update and reload the 1.2.11 firmware.
To perform factory reset, remove DC power, plug in a shorted RCA connector in PTT A in. Hold Op/STBy button and apply DC power. Continue to hold Op/STby until it is reset.
Remove power, remove shorted RCA and power up and configure.
73 Dave wo2x0 -
I did as described, but when having shortened RCA in PTT A IN and hold the left BYPASS/OPERATE button and power on, I just see 3 little dots on the screen and nothing happens next 10 minutes0
,tap the dot. It will move. Tap it again. Then a third time. That is a touch screen calibration.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
