Utilities doesn't show LOCAL DEVICES
V31DL
When I use the Antenna Genius Utility, Tuner Genius Utility and Power Genius Utility, all do not show me the devices under LOCAL, even though all devices and the PC are on the same switch. On other PCs in the network, the devices are also displayed LOCAL in the utility programs.
What is the reason for this or what is the logic behind it?
firewall on the one PC.
Possibly the antivirus/firewall software was updated after the apps were installed?
First, I would open a command prompt and run ipconfig to verify PC IP and Genius products are on same subnet.
If so, you can try uninstalling the three Genius apps, reboot and reinstall the apps. This will recreate the firewall rules.
Latest PG XL is 3.8.8
For AG/TG make sure you are using right pairs. Either AG 3.1.5/TG 1.1.20 or AG 4.1.8/TG 1.2.11
Contact me via direct messsage on the Community if you still have issues0
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
