I/Q Bandwidth
What chunk of bandwidth is represented by the I/Q output with a 6600? And is that bandwidth centered on the center frequency of the slice?
Best Answers
Thanks Len!
In Dax, you can set the I&Q to 48, 96 or 192 kHz. It is centered on center of panadapter display.
Greatly appreciate this valuable info...thanks!
Hi Jim, the maximum IQ bandwidth of the 6600 is 192 kHz. I am not sure where it is centered, as multiple slices can be open in that space.
I just sent Mike a message about this and then found this post. Apparently not everyone has 192000 available. I have talked to a couple people that says theirs has a max is 96000. Any idea why?
I wish Flex would listen to feedback from developers about how the IQ is coupled to the center of the panadapter. It causes issues.
Yuri from SDC says because of this when changing bands using the band selector on the left of SmartSDR it breaks the IQ audio stream on his skimmer. Its a Flex issue he cant fix. You have to close SDC program completely and restart to make it work again. I talked to Don at Slicemaster and he has to close CWskimmer and reopen it again to get around this band switching problem. You can type a new frequency in the slice and it will switch fine but apparently when you switch bands via the band buttons the program kills the slice and creates a new one which breaks the IQ stream.
I'm told that the 6600 can output 192 kHz of bandwidth, but that the 6300 outputs 96 kHz. Perhaps this number varies with the number of slices that can be open simultaneously on a specific model radio.
Hi Jim, I see now that my 6400 only goes up to 96,000 samples per second. I am guessing that this is due to the 122.88 Msps of the 6400 ADC vs the 245.76 Msps of the 6600 ADC. Maybe Flex could chime in and let us know for sure.
For what its worth it appears not all 6400s are created equal. I worked with an older 6400 yesterday that was limited to 96000 and talked to someone today with a newer one that does 192000.
Having 192000 is actually pretty nice since Flex chose to tie the center of the Panafall to the center of IQ stream. The IQ band plan control window on the SDC program is a very good example that you can be missing spots when running a skimmer when our bandplan goes outside of the IQ stream. Still does it on some bands with 192K but obviously much less than it does with 96k.
- 359 Community Topics
- 620 The Flea Market
- 8K Software
- 27 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 928 Maestro
- 902 Genius Products
- 325 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 981 Third-Party Software
