Multi-account user
k2der
k2der Member
Is it possible to implement multiple logins within the SmartSDR software? For instance, I manage four stations, and presently, each time I switch between stations, I must log out and then log back in. Although it's not overly burdensome, it would significantly enhance convenience if I could log in once and seamlessly switch between stations thereafter.
My query differs from those typically found in the community forum. In my scenario, I am a multi-account user.
Not all of them are mine, hence the inquiry. I also encounter situations where friends invite me to used to their radios.
It would be good to implement in the future if this is possible.
Thanks in advance for help and comment 73
6 votes
Active · Last Updated
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    The Flex remote system calls out for a system of user logins and permissions to let you log in to one of multiple radios, as you want, but also on the radio side, so you can tell what user is trying to connect to you.
    It should work like a Linux login server, in other words. Logical, but maybe limited ROI for Flex.
    73 Martin AA6E
