Band width indicator
Should be to the right.
Hi David, can you post a screenshot of SmartSDR?
Here is a screen shot. the bandwidth shading is on the upper side of the frequency line
I have to click on a freq band width number in the dropdown for it to move to the low side of the frequency line0 -
Hi David, your picture shows the proper location of the upper sideband. What is leading you to believe that it is wrong?
sorry i had a power outage the shot i sent is a normal after i selected the bandwidth button i will try to upload the image again as it appears right after changing channels0
Yep, this one is near the 80 meter band, and therefore shows lower sideband as it should. If you go back to 10 meters, it should automatically go to upper sideband. Is 4.069.700 a MARS frequency by any chance? If so, are you expected to operate upper sideband? If so, you might want to create a profile that selects the sideband of choice.
I also notice that you have DAX selected. Are you running a digital mode? If so, you probably want to use DIGU instead of USB.
Weird Min shows correct for 4.069.700 USB but my Radio is Unlocked for MARS frequencies.
If your Radio does NOT have the correct TURF file and this is out of band than that could be your issue.
If you have the correct TURF file then I would try a Hard reset on the Radio and DON'T load in any Profiles until after you check it out to see if it is operating properly.
Do you have ANY 3rd party software running like FRStack or the like stop running it during your testing.
This is on my Flex6700
i do have the out of band turf file and kit.
I will try what you suggested on hard reset.
I am told that USB is adequate/normal for the use I’m working with. And it does work as required. However it’s annoying when I go to the freq. and the usb band width is the wrong direction.
I updated to the latest version of smartsdr. Against my better judgement because the frequency memory file is dumped when you do a update and I have never been able to reload a settings file. However, the problem of the band direction went away with the version update. I guess this thread is now solved. but, i still do not know why it did that.
update; on another thread I was able to find the frequency memory file (cvs) in the saved profile list,.
Now i will not be working overtime to recreate a large frequency list on software updates.
thanks for all comments
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
