Software settings for MS-DMT MARS software with FLex 6500?
N1UW
N1UW Member
edited November 2019 in SmartSDR for Windows
I use my 6500 for MARS operation.  I have it running happily with HRD/DM780 but cannot find the settings in the MS-DMT setup to make it key the 6500.
  • K6OZY
    K6OZY Member ✭✭✭
    edited August 2017
    I use DAX 2 for my MARS MS-DMT and then setup Virtual Serial Port for an interconnect between MS-DMT and MsgTerm using COM 1 / 99 pairs.
    Pictures say a thousand words, so here's a snapshot of the config pages for my working setup.  You must use a PTT Port to trigger.
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    edited July 2015
    I do the same with Flex 3000 and PowerSDR.  DDutil is involved too.
    Andy AAR2BY
  • N1UW
    N1UW Member
    edited December 2016
    This did the trick!  My settings are only slightly different in terms of the actual com port used but the general principle is right on. Consider the question answered.  Thank-you.
    73 Frank N1UW
  • Andrew O'Brien
    I have not used MS-DMT these days
    Andy K3UK
