Flex Tuner Genius
Coax to antenna 1 is connected via A ports on radio, amp and tuner and to antenna 2 via B ports on radio, amp and tuner,
Tuner works as it should on antenna 1 but when trying to tune antenna 2 the tuner readout shows "no band data" and will not operate.
How do I convince the radio to send band data to the tuner?
Mike, WM5DX.
I had that happen a couple of times this week. I'm running Flex-6600 v3.7.3, Ant Genius v4.1.7, TGXL v1.2.11, and PGXL v3.8.4. In each case, just holding down the my key (dashes) in CW mode for a second (with PGXL placed in standby mode) fixed it, and the error did not reoccur again that day. Previously, I tried powering ON/OFF all these equipment, but that did not fix the issue. YMMV
In Tuner Genius setup, make sure in Flex Radio tab that B is enabled and has the radio s/n , Ant2, and LAN PTT selected.
The tuner will not switch to in circuit until you PTT or hit CW key. Make sure radio TX delay is at least 30 ms.
Also in all Flex setup the Genius Integration tab should not have the Power Genius selected.
73 Dave wo2x
David, WO2X.
Thank you for the response, much appreciated. I rather jumped the gun with my post, ten minutes after I posted I read the Tuner manual and found the answer! Now tuner is working ok with both antennas.
Many thanks again for posting, I will not be so hasty in future and will endeavor to operate my brain before operating the keyboard!
73, de Mike, WM5DX.
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 932 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
