Been gone a while, good to be back
It's been a few years since I've been here. I boxed up my radio to return it to Flex for the fan I believe 3 years ago and then life took a turn and we had event after event occur causing me to miss two RMA's and leaving my home office alone for almost 3 years. I got out of the hospital after the latest event and I'm home doing rehab and I'm allowed to finally go into the basement and reassemble my shack. The first event was a flood from the 3rd floor down to the basement, thankfully my Ham gear wasn't hurt but had to be moved to dry out the house which required gutting from top to bottom and rebuilding, the rest is too long to get into and well, yeah...
Anyway, I plugged in my 6300 and she fired right up! Fan sounds strong while I'm doing the upgrade to v2.12.0 and I'm going to try and use it a bit prior to replacing the fan.
Antenna is hooked up but sadly no signals appear in the app... time to dig in and see what the... is going on.
Amazing what an antenna switch will do when you forget to set it....
Welcome back! Like you, I’ve just recently returned after a multi-year hiatus (due to a whole raft of things).
it IS great to be back in Flex-World, isn’t it!
"Multi-year hiatus (due to a whole raft of things)." 1000% right there with you! Welcome back as well. 🙂
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
