How to connect to a 4o3a Rotator Genius over WAN?
Stan ka1ze
I am able to control the Rotator over the LAN but not over WAN. I have set PORT FORWARDING to pass the TCP PORT to the controller IP address.
Thanks for any ideas.
Stan, KA1ZE (W3XTT)
Stan, KA1ZE (W3XTT)
Hi Stan,
I do not own the RG but here are some ideas.
When remote - use your external IP address. You can find that by using your station PC and go to What Is My IP | Find my Public IP Address - IPv4 & IPv6 (whatismypublicip.com)
When setting up Rotator Genius, use port 9006 and make sure your router is forwarding external port 9006 to internal port 9006 and IP of Rotator Genius.
If your ISP uses CGNAT then it will not work since they would need to do port forwarding in their network.
73 Dave wo2x
Thanks Dave, my IP was also no problem.
Stan
How do I find out about CGNAT?0 -
Go to Myip.com
see if the IP shown matches your WAN IP on the router. If it doesn’t then you are CGNAT. If it matches, contact 4O3A.com support as they support the RG.
Thanks Dave, I will need to ask 4o3a.
73, Stan
- 369 Community Topics
- 628 The Flea Market
- 84 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 915 Genius Products
- 332 Tuner Genius XL
- 450 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
