Flex 6400 microphone
gunlocators
Does all types microphones work with the flex? I have a 6400 I tried hooking my cheap dynamic mic to the trs port using a trs to xlr cable off Amazon also using a foot switch to key and it is not working. Flex hand mic works fine even when I use my foots with to key. Anyone have wiring diagrams for trs to xlr 3 pin using a cheap dynamic mic?
Check your cable. It probably should be Pin 1 to sleeve, Pin 2 to tip and pin 3 to ring.
In the Flex you will probably need boost on and bias off.
John N1JM
This cable from Amazon worked for me.
John N1JM
- 632 The Flea Market
- 126 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
