3.6.8 flex 6400 not turn on Expert 2k-FA
John Stransky
Member ✭
Did work prior to install 3.6.8l
Hi John, I haven't seen you in a very long time!
I would check the TX Band Settings screen to be sure that the proper RCA jacks are turned on. Also verify that the corresponding jack is plugged into the amp PTT jack.
In my case, TX 1 is plugged into the PTT jack of my KAT 500 tuner, which then plugs into the PTT jack of my KPA 500 amp. I use TX2 and TX3 to run my 2 meter transverter PTT and 2 meter amp PTT.
If this is not the problem, post back with more info on how everything is connected and what the symptoms are.
Thanks that fixed it John0
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
