Right angle 6-pin mini-XLR?
I couldn't find an obvious category for this question, so my apologies if this isn't ideal.
I have the Flexradio-edition RS60CF-10A, and it's a beautiful piece of equipment. My only gripe is the long, rigid connector that protrudes from the base of the left earcup, such that the cable drags on my shoulder and makes quite a bit of noise every time I move my head.
I have looked for, but have not found, a right-angle adaptor for the mini-XLR plug at the earcup. I think that would alleviate the problem. Does anyone know of a source for such a thing?
Look to see if any of these items, meets your need:
https://www.google.com/search?client=firefox-b-1-d&q=Switchcraft+TARA6FX#ip=1
Yeah, I found those connectors; however, I was looking for an adaptor for an existing cable (wasn't really thinking of replacing the connector), but thank you.
I solved the problem on the cheap. This worked fine: https://www.amazon.com/Degree-Rotate-Earphone-Clothes-Headset/dp/B08BL44TW4/
Thanks again.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
