Tuner Bypass SO2R
Question
Has anyone using the Bypass feature on the Tuner Genius mine is SO2R.
I can't get mine to bypass unless I press the bypass button and or use the App.
Version 1.2.11
Ian
KM4CQG
I can't explain what happened to make my TGXL bypass feature STOP working but I just did factory resets (again) of both my AG and TGXL running v4.1.7 and v1.2.11 respectively for other reasons and now it's working again. Glad about that of course but weird ...
Russ KR6W
2
I tried my TGXL and it does bypass but does not show it in bypass mode.
Looks like mine required a Reset and needed to be reprogrammed.
After all of this STILL NOT Working anyone have any idea's
Thanks for checking BTW the Mic is doing well using it on the Maestro.
Ian
Update on findings.
The Tuner Genius when working alone is working properly.
When I tell the Tuner Genius to use the Antenna Genius located on the Genius Integration tab I get the error.
The Tuner Genius stays in line under the integration with Antenna Genius.
I imagine it's a software fix from 403a.
Ian
KM4CQG
Yup, I'm seeing this too. Except in my case the bypass selection feature isn't even working when not integrated through the Genius Integration tab with the AG.
I know this worked properly very recently because I had to do factory resets of both the AG and TGXL after updating to v4.1.7 and v1.2.11 respectively following Dave WO2X's advice to GET it to work.
The only thing I've updated since is SSDR to v3.6.8 but I don't see how that would have anything to do with this. Very weird ...
Russ KR6W
Is version 1.2.11 for the TGXL a Flex tested and supported release?
I am only seeing 1.1.20 as the newest release on the Flex site. I know in the past if you wanted to live on the bleeding edge that 4O2A has had newer releases on their website for download but when I have done that it has resulted in some kind of inter-operations issue.
v1.2.11 is indeed from 4O3A’s website. It’s required for their v4 AG firmware.
Russ KR6W
Tuner Genius 1.2.11 version still has the same issue again when combined with the Antenna Genius version 4.1.7
Ian
KM4CQG
Russ
Thanks so much I tried your solution and it worked.
While it does not show Bypass on the App all the circular indications now go to 0 when I transmit using the Bypassed antenna's.
Ian
KM4CQG
Correct.
When in bypass the C1, C2 and L will show zero.
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
