Mic Audio Just stop working
N8XYM
Member ✭
Win 11 / SmartSDR v3.6.8 Using Mic connected to the computer.
I got on my Flex 6400 a few days ago and could not TX. I have no TX audio. I check the mic and it works on other programs but can't get it to work on the flex anymore. I check for all updates, removed it and re-installed it. I have been off the Flex for a few months and thought I just have something set wrong but if I do, I cannot find it. Any idea's
Well, I thought this was a computer issue, but I just tried my iPad and I have the same issue.0
I believe most PC equipment uses TRS type plugs (tip+ring+ground) and iPads use TRRS type (tip+2-rings+ground). Have you checked PC microphone input settings. MS update my have changed settings.
You need to be sure that you have PC selected and that DAX is off.
To use a mic plugged into the computer, you need to set it as the default recording device.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
