Flex 6600 Selected Antenna Indicator
WK1O
I am looking to get an external signal to control the switch to show selected RX antenna - ANT1, ANT2, RXA, RXB
The Hi-Z array is located physically very close to 4Sq on 160M and the 4 Sq needs to be detuned when RXA is selected by the radio.
Does anyone know how to get the get this info into the relay switch?
I see FRStack gets this info from Flex. The question is how to get this signal into one of the ports?
I am sure somebody solved this already. I just could not find it in the discussions.
Thank you much
Alex, WK1O
Hi Alex, you can use an external relay board (e.g. Denkovi) to switch on certain conditions. If RX Antenna, RX A or B is selected + frequency range or band set relay "active high" or "active low".
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
