PGXL error msg
Hi All,
Just got this msg on the Maestro display: PGXL reducing power. Please stop transmission
SWR is very low so that should not be an issue.
What can cause this message? Can't find anything in the manual.
73 de Adde, SM0SHG
You don't give us much info to work with but my guess would be the temperature of the finals is getting too high.
Gordon, ve7on
Well, that is the info I have. I have never seen this error before and can't find any information about it.
If it was related to temprature I would expect some type of temp alarm. The PGXL was around 40°C
Adde
Important to give the current firmware Version that is on the PGXL?
What was your Drive "RF Power" Slider set at on the Radio and the Modulation MODE you were using? NOT the "Tune" settings
If your NOT over Driving the AMP with the "RF Power" set to high then
Is the AMP set for MEffa enabled or Disabled?
What is the TXD (Transmit Delay) set for?
Start out at 30ms and increase up to 50ms if the problem keeps coming back and see if it still does it for a test, personally I have to run mine at 40ms.
If you can answer these questions it would sure help us help you.
Bret
WX7Y
Hi Bret,
Settings as follows:
3.8.4
10-12W
Enabled but this is only for CW, right? This was during SSB.
This is set to 20. I think this is the recommended setting from Flex? But will set it per your suggestion and see if it makes any difference.
The issue has so far only been on 17m. Was running in the UBA contest this weekend on 10 15 and 20. No issue what so ever.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
