How Accommodate Multiple Headset / Mics ?
How are folks who use / switch between headset and microphone operation handling this? Is some type of switch box available somewhere or is the only solution to use a USB headset which operates through my PC?
Having to pull the unit to swap cables on the back is not workable (practical) for me . . .
Thanks Craig . . . Glad to see such a device exists . . . If I'm already shelling out $3,400, not feeling the need to build and save a $1 if an off the shelf device already exists :)0
Why not just build a box with the appropriate connectors and a switch?
Or, if you just want to buy one, go to Amazon and search for 3.5mm TRS Switch box. They have a nice variety for very reasonable prices. Add a M-M patch cable, and you are ready to go.
But, as Geoff noted, building one is trivial. All the parts needed are available at Amazon.
73, Craig KØCF
I incorporated a mic switch into my TeensyMaestro. It changes mic profiles based on a config file parameter on an SD card. It only switches between two mics. In my case, I have a Heil HM-12 dynamic mic and a Yamaha CM-500 headset with an electret mic.
Most will not want to build a TeensyMaestro just to get this feature, but if there is enough interest, I would be happy to create the Teensy 4.1 software to allow switching multiple mics and setting their mic profiles accordingly. The Teensy 4.1 board plus ethernet jack and cable is around $36 USD. You would need jacks and a switch and a project box to finish it off.
Things that could be incorporated very easily would be an out of band indicator based on license class, "permanent" spots to show favorite frequencies, nets, repeaters, etc. as well as a memory keyer. These items would port easily from the TeensyMaestro and would take little to no extra hardware (just jacks and buttons for the keyer).
Let me know here if you are interested and what additional features (if any) that you would like to see. If even a few folks want this, I will start a new topic and start working on it.
When I’m using computer based SmartSDR on the PC, I pick the microphone I want from “mixer” software. I leave multiple microphones plugged in. Desk mic, headset mic, Bluetooth headset. I have each assigned to a different mixer channel so that the audio levels are correct. Adding complexity, I have Elgato Wave, which adds virtual effects (equalizer, noise gate, noise reduction, audio compression etc.) which is customized for each microphone. I just make sure I have only one microphone selected at a time. I use an external PTT connected to Serial/USB and FRStack for keying via a hand switch and foot switch connected in parallel. I don’t need to make any changes in SmartSDR when I change microphones.
If I was using microphones attached to the rear radio input, I’d have an outboard mixer, and essentially mimic the same set up. It’s called Flex for a reason - lots of ways to set it up. Mark - wd9jen.
- 651 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
