DAX TX audio issues on Intel NUC 13 Pro
JamesW7EY
JamesW7EY Member ✭✭
edited January 2024 in DAX
My new Intel NUC 13 Pro running Windows 11 has an issue while transmitting with DAX that causes blips in the audio. I have two other computers that work fine. The audio going into DAX sounds fine and I was able to use Virtual Audio Cables to mirror the audio out to another device and make sure it doesn't have the blips. PC Mic audio is unaffected by this. I even tried just playing a 1khz sine wave file from audacity into the TX. The blips happen even at 1 watt. Network is local gigabit lan and shows full green bars in SmartSDR. Has anyone else run into a similar issue?
I made sure I updated the BIOS and drivers. Passmark benchmark ran fine and shows a decent CPU score.
This is what the TX looks like.
  • Graham999au
    Graham999au Member ✭✭
    Select Properties for your ethernet adapter, then Configure, then Power Management, then turn off "Allow the computer to turn off this device to save power".
    There is also a guide somewhere by Flex on other adapter settings to check, but that's the main one.
    GL and 73, Graham VK3GA
  • WX7Y
    WX7Y Member ✭✭✭✭
    This looks more like a broken driver or maybe a windows firewall issue to me.
    You may want to do a help desk ticket for this one, they should be able to help.
  • JamesW7EY
    JamesW7EY Member ✭✭
    edited January 2024
    It must be something to do with the Intel ethernet because it's not happening on wifi. I poked around with those settings mentioned and turned off "Allow the computer to turn off this device to save power" and it's fixed. Thanks!
