CPU Overcurrent
This morning after doing my weekly power cycle of my radio (due to the CW bug) the 6300 booted up to blinking 5 times, which indicates a "Cpu overcurrent" state. This is a remote site that I was able to view via my onsite shack camera. I have never seen this on any of my radios before. After blinking 5 times for 30 seconds or so, it shuts off.
Since the radio is at a remote site, I can't run any in person tests until I got up there or have a friend swing by, but wanted to see if anyone else has ever gotten this error and what the solution was. I'm hoping it's a power supply issue and not a radio issue since Flex currently has my 6600 and this 6300 is my backup radio.
Thanks for any help,
Peter - WB6POT
Update:
My ham friend who lives 2 miles away from my remote shack and has keys to my shack, went over this morning to run some tests. As soon as he arrived he called me and I told him I would remotely boot the radio so he could see the flashing lights, etc.
However this time it booted normally and everything was back working. I had done this exact reboot (power supply from off to on and then soft reboot) at least 3 or 4 times prior to him arriving with the five blinking lights followed by the radio powering itself off.
I have no idea what changed, but now I'm afraid to power down the radio. Everything currently is operating fine. I'll hope for the best and will update this thread if things change.
Peter - WB6POT
Do you have any USB devices plugged into the Radio?
If so they may be what is causing the shutdown problem, If you are using USB devices on the FLEX you may want to purchase a POWERED USB switch and plug all your USB devices into that so you only have the Powered USB switch plugged into the Radio.
I ran into this years ago when I had the 2M AMP and a USB Serial port plugged into the Flex6700 and it would intermittingly shut down the Radio.
Amazon has some pretty good METAL case for RF shielding, 12V USB switch's that will use the same Station 12V supply the Radio uses so you wont have a ground loop problem.
No USB devices plugged into the radio.
Peter - WB6POT
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
